Evinrude 150 Intruder (E150GLECD) Rebuild???
jchristi
The question that I have is should I rebuild my powerhead, or just keep running it? Here is the story below:
At the end of last season were were at the lake as usual, wife was skiing and engine seemed to have just a little less power but I didnt think much of it at the time. Finished skiing and were idling back to the dock when the 'No Oil" light came on and the engine quit. The fuel ball was soft, pumped it and started it again. It started right up with the oil light now off, idled for about 10 seconds and the "No oil" light came on and it quit again. We got towed back to the ramp and took it home. I went through this start up process a few more times while trying to figure out the problem. I eventually traced it back to the VRO pump, I replaced that and it started right up, smoked, and idled fine and the "no oil" light stayed off. When we went back to the lake it seemed to idle a little rough (although not bad, just seems to "cam" a bit in gear) and had a slight miss at take off at about half throttle. It ran pretty good otherwise.
I am a paranoid sort so I thought I had better look into it further to make sure I hadnt screwed something up since I technically ran it for a short time with no oil. I checked the compression and the starboard bottom cylinder had 90lbs, while the others had 110lbs. I pulled the heads so I could look at the cylinders and they all looked OK except the starboard TOP cylinder had scores. No metal was welded to the cylinder walls. The cylinder that was a little low looked ok.
Should I just keep running it until the problem makes itself obvious, maybe decarb the low cylinder and rebuild carbs. Or should I go ahead and bite the bullet and rebuild it before any more damage is done? Thanks in advance for the help!
Jason
juanjuice
Re: Evinrude 150 Intruder (E150GLECD) Rebuild???
rebuild it before it gets worse and put a whole in the block you know you cant rebuild it if you get a whole in it i dont know where you are but im in ga and can rebuild that for you for a good price are let you trade that one in for one already rebuilt i have a few motors call juan 7707159738
jchristi
Juan. Thanks for the reply. That is what I figured too. I was just wanting a little push to help me spend the money on it. I think I will give it a shot myself. Have a little bit of experience with this stuff. Currently looking for someone around my area experienced at boring outboards. Planning on rebuilding the carbs too. Not entirely sure it was the VRO that did this, may have been those carbs running lean.
