Evinrude 15014-518561
my old boat
I have this motor but i do not know what year or size it is ? i think it is late 50's or 60's.
tashasdaddy
Re: Evinrude 15014-518561
that is a fantastic, motor, strong, dependable. easy to work on. most parts available at laingsoutboards.com. just resently sold mine, bad mistake selling it. for around $140 you can rebuild the carb, replace all the electrics, and impeller, and it will be like new. check you compression, before buying anything. to be sure it's doesn't need anything else. the leg of that motor has to be submerged in water atleast 1/2 way up, as the water pump in in the bulge in the leg, and has to be under water. i use a big garbage can. just refurbed, a 58 35 hp.
