Evinrude 15hp
enn
I have a Evinrude 15 hp 1991 - the engine only runs around 10 hours a year (short summer here in Denmark) the engine only runs in Fresh Water now my queation:<br />How often should the Water Pump be serviced??<br /><br />Greetings from ENN in Denmark
JB
Re: Evinrude 15hp
Howdy, Enn.<br /><br />Age, more than use, wears out impellers by making them brittle.<br /><br />I would change the impeller at least each 2 years.<br /><br />Good luck. :)
Boatist
Re: Evinrude 15hp
Enn<br />I can't disagree with JB as almost everyone will tell you the same, every 2 Years.<br /><br />However I have a 1975 Johnson 15 HP that in it first few years ran a lot in shallow water and mud frogging. I changed water pump in 1981 and put in a chrome or stainless pump kit. Last year I was going to change again as had lower unit off to change from a 15 inch shaft to 20 inch shaft. When got ready to do it I took impeller out and could find no wear at all. The tips were all perfect and could find no cracking in any blade. Only thing I found at all was impeller did not go all the way out straight when out of cup. Still fills the cup with plenty of spring so I put it back in. Pumps plenty of water at low speed as well as High speed. My 1980 OMC I/O has been changed twice when other work was done but all the old parts look fine.<br /><br />I never start motor with out water going to pump. Today I never run either motor in mud or sand just normal River, Lake, and Sea Water. I do not change my car belts every two year either but do change timing belt every 100,000 miles.
enn
Re: Evinrude 15hp
Thank you everybody - i will inspect the pump and have bourght a complete water pump kit in case anything needs to be replaced.
