Re: Evinrude 18hp 70 again need help from Germany
Hi Florian.<br /><br />If I may, I'd like to ask a couple questions.<br /><br />Have you done a compression test on the engine? How does it idle, good, fair or poor? If you have had the lower unit off, when it was put back together, was the shift rod link aligned with the shift rod grooves when the screw was put back in? I'm not sure I would believe the reeds are damaged. If they were that bad, the engine probably would not run. If the engine does idle, look for blowback from the carb. If you do have a broken or cracked reed, you will notice fuel/oil mix laying in the front of the lower pan. The compression test is to determine, to some degree, that there is no internal damage to the cylinders such as broken rings that may be stuck in the head. This could cause any fresh fuel entering the cylinder to fire at the wrong time. It may not happen on every stroke of the piston. Hope we have added some good info. Keep us posted. Thanks and Good Luck!!
