rickycobble
- Joined
- Sep 13, 2016
- 28
The 18hp Fastwin is cutting out when I get to around half throttle and on up to WOT. I can go WOT and prime the bulb and its okay for 30 seconds or so and then I guess the bowl is going dry, starting to cut out intermittently, in which I can prime the bulb and its okay again for another 30 sec or so. Carb has been cleaned, float and needle replaced. Float set to level with bowl surface, also set float drop to 1 1/4" per someone in another topic in this forum. Fuel pump is new. Fuel lines and bulb are new. The fuel tank and the fittings on fuel tank and motor ARE NOT new. Gas is 50:1. Any help is greatly appreciated. Below is a video where I'm running it at about half throttle without priming the bulb. You can hear it briefly cutting out while the bowl fills up.
