Evinrude 1961 5.5HP.Disconnecting shift shaft ?
Lyse
I need some help to know how to remove the arm of the shifter to be able to disconnect the shift shaft because I want to change the water pump. So, if someone knows how to do that, I would appreciate to have some explanations about that. Thank you.
Bear
Re: Evinrude 1961 5.5HP.Disconnecting shift shaft ?
I did a search here for "5.5 impeller" and found these:<br /> http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=17;t=001224 <br /> http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=17;t=011521 <br /><br />I think your gearcase is looking like this:<br />Picture (click) <br /><br />No manual? Hmm. We have to mention it, you know ;) You should GET ONE. Sorry could help it.<br /><br />Good luck and get back here for help if you need any. :)
Dhadley
On that one you need to pop the powerhead off. The shiftrod is connected to a pin on the shift arm. <br /><br />Good luck!
Lyse
Thank you very much Capitaine Bear and Dhadley for your help. Capitaine Bear i will try to get the smileys as you mentioned thank you .
