Evinrude 1961 V4 75hp water in cylinder
stueywatson
The motor starts and runs for a while. When I got it it had wrecked threads on the sparkplugs on one side.( I had an inserts put in.) After running there is water in the lower cylinder on one side and a gurgling sound from the air inlet when the motor stops. I have had the head gasket off and it is okay. Is there a break through area between the water jacket and the inlet manifold?
gas hog 75 rude
Re: Evinrude 1961 V4 75hp water in cylinder
did you find out what the problem was, because i have the same one with my 1961 johnson 75? if so can you tell me what had happened.
thanks!
CharlieB
Sorry Gas Hog,
Notice the DATE on the original posting?
I think you will get better results starting a NEW thread, use a similar title with your motor.
While you wait for a response, remove the exhaust cover and inspect for a bad gasket or a hole corroded between the exhaust and water passages.
kenmyfam
thanks!
Start a fresh thread as stated already.
Welcome to iboats
F_R
Welcome to iboats
Maybe you can cut to the chase and check the hoses to the automatic choke. They don't like to have the water hose connected to the vacuum source nipple.
Willyclay
F R, you didn't have to tell the whole planet what I did!
