I tried to pull the lower unit off to check my impeller and got the shift link undone and free and the lower unit would still not slide off. Then I forced it down and the lower unit came off. The only problem is that the drive shaft is still in the engine.
Did I screw up bad? Why did this happen? Was I supposed to unscrew the drive shaft somehow?
Thanks guys!
Thanks guys!
