RSO117
- Joined
- Jun 29, 2008
- 20
Need help if you can. Was out in the bay on Sat for a few hours just cruising have a bit of a run then after one of several stop go moments whilst idling engine died. Thought nothing of it as we were dropping anchor anyway. Wet a line for nearly 30 minutes then decided to move on. Guess what.., lots of cranking but no fire. Tried for nearly an hour. choke on, choke off. Fuel was good. changed tanks over. compression was tested a week prior at 140psi per cyl. Engine just would not fire. engine eventually flooded. When we finally got it home checked spark and there is no spark in any of the 3 cylinders.
Have checked all wiring for nicks or breaks but all good. Does anyone know of any common or inherent problems with engines of this era and HP. Not really looking forward to what the mechanics going to say. If it is power pack are these expensive. I had already replaced one of the coils due to cracking. Does it matter if the replacement coil was different looking i.e. black rather than the light green colour of the other two? Do these models have contact points.
