I have just bought a cheap 1975 115HP Evinrude. I was told that one cylinder is down on compression 90psi the others are 110. I have to check these, but is this a good model to rebuild? I recently re-built a 1977 70HP so it looks pretty similar. Also it doesn't have tilt & trim, since it use the old hard to get twin ram exteernal unit, can the power head and gear box be put on a latter mid-section with internal t&t/
Thanks in advance
Thanks in advance
