1975 - Model 15504C Manual/Pull Start - Low Hours - Like New<br /><br />Engine unfortunatley happened to be lying in three inches of SALT water on Saturday AM, you know enough to get inside and visit the cylinders and all the electrical parts. Tide came in while on a hunt and the engines where supposed to be on high enough ground. I was not there when it happened and I asked what side the motor was laying on and neither of my two friends remembered. I seem to think it was the coil side.<br /><br />Engine was immediately sprayed inside and out and cylinders cycled numerous times. Engine store sprayed inside of engine as well. I also parked it in the garage under two 500 watt lights to dry it out.<br /><br />The stator and coils were soaked and the spark plugs were removed and water poured out of my Buddy's Johnson 15hp 2004. So I figured it did on mine too. We tried old coils off of old engines from my Buddy's out board cemetary on the Evinrude. No luck. I think the problem is in the stator. Unit will not turn over or run at all. The closest I have come is exhaust smoke after it almost stayed running this AM.<br /><br />Any suggestions? How can I test the stator? I also did order a manual (owners and service) as well as a parts manual but I did that last night on-line. Should the whole thing be taken apart? I do not have any experience with this or any outboard. All I have done is run 'em.<br /><br />I know and I read about the "directness" of this site but I had to post this as a "OH NO" This engine, boat and trailer was purchased by me on Firday night and I intended to use it the very next day but my wife was sick and I was unable to go on the hunt because I had to care for our daughter. I let two of my friends use the boat. I have never even run the engine yet. Bummer!
