Evinrude 1979 25 HP Water Pump
I am having trouble dropping the lower unit to change the water pump. I have removed the 4 bolts,the stud nut and disconnected the linkage rod. I have .006 clearance around 340 degrees but the unit will not drop. Is there another pin somewhere that must be removed?
