Hi. My tender/ auxilliary motor normally is ultra reliable and gives me great peace of mind as a backup. Just lately though is will go through a period where it will just not start at all. Not even a pop. Leave it for a while and it's back to being old faithful.
I would like to get to the bottom of this. Two possible symptoms. I have noticed that before it starts acting up I often get a hell of a shock during the preceding run on startup where the coil seems to be grounding. At that point the engine still runs like clockwork but the next startup is a non event. The other possible symptom is the engine has been lying horizontal / flat either in stowage or in the car boot (i.e. will not start during the fresh water flush out after performing well at sea all day)
I have checked for obvious grounding issues but cannot see anything out of the ordinary. All leads look to be in good condition and making good contact. Both plugs get very good spark. Engine is immaculate despite it's age and only alteration from original is the wiring in of a saftey cutout lanyard inline with the engine cut-out button on the tiller arm. Where should I start troubleshooting from?
