It takes a lot of cranking to start, after starting shakes a lot at low RPM, till you passed 2000 RPM, Please Help, the engine will stop on water at low RPM, high RPM runs perfect,
although the 2 cylinders that are 70 could also cause engine to be out of balance 20 PSI is a little over the recommended tolerance of %15. maybe try a decarb, and replace head seals.
