Evinrude 1997 FICHT engine - blew small hole in crankcase
jackman1939
I bought this engine new in 1998. It has always run very good. I use 7712 plugs and after reading the indexing information, I always index the plugs. The #3 plug always seems to be grossly fouled after only 2 trips (30 miles each). I clean it and reinstall it. The engine usually tacks out at about 4300 rpm. I have a 1996 OMC Neptune center console boat. The prop is a 14 1/4 X 21. The boat usually has a max speed of 44 mph. The last 2 times I went out, I noticed the top speed was only 39 mph. Ran fine though. Went out Saturday and decided to come in early because of a big storm approaching. Was tooling along at top speed for about 10 minutes, when all of a sudden, the engine made a loud noise and started running very sputterly. Saw a little smoke coming out from the cover. Turned the engine off, took the cover off - it looked ok. Started right up, but sounded terrible. Shut it down and called Sea Tow. When I got home, I took the cover off and removed all the plugs (they all looked ok). Put my finger over the spark plug hole and had my wife crank the engine – all cylinders had compression and suction. Upon further inspection, I noticed a few pea sized pieces of metal laying inside. Spotted a hole in the crankcase, between cylinders 2 and 4.<br />Hooked up my laptop, connected the test wire from the engine to the serial port and ran the OMC diagnostic software. It came up with 1 error code: "Intermittent 35 - oil pressure switch malfunction. Oil pressure switch is not opening or the switch harness lead is grounded".<br />I got not indication on the OMC instrument cluster of any oil problem. Checked the oil reservoir and it was 3/4 full. Pulled the rubber line off the metal line where the oil comes into the engine. Hooked up a piece of clear tubing to the metal line and sucked on it - oil was present there.<br />SOOOoooo, I am getting ready to tear the engine apart and try to fix it.<br />About 4 years ago, the oil light and beep came on every now and then. I replaced the oil pump and that fixed the problem.<br />Any tips you can give me would be appreciated. I am not an outboard engine mechanic, I just am pretty good at fixing stuff.<br />thanks,<br />Jack
seahorse5
Re: Evinrude 1997 FICHT engine - blew small hole in crankcase
Chances are the damaged rod and broken crankcase were due to overpropping the motor and causing it to "lug" itself to death.<br /><br />That motor should have been propped for 5300-5500 rpm which would have been at least a 17" pitch prop, not a 21" turning only 4300 rpm.<br /><br />It is not economically feasable to rebuild your motor as the '97 and '98 versions have next to no trade in value when they are in good running shape.
