Water wasnt pumping through my Evinrude 2.3 (1995, Model HE2RETA, Serial H9290519)<br />how much bigger than the housing should the impeller diameter be? I just opened mine and the rubber blades are bent a considerable amount ...not sure if i should replace with the same size or slightly smaller. No indication in the manual as to the replacement impeller part number for this motor. Also ...trying to figure out if there is a blockage in the water routing...blowing down the outlet pipe seems to let air through ... but takes a considerable pressure...should this be easy to blow through...?
Thanks ..Joe
