Evinrude 200 ficht
Blueglass49
I have a 2002 evinrude 200 ficht and can’t get power to the starter solenoid. Replaced the ignition switch and solenoid but still nothing. Instruments and warning lights are working, starter cranks when hot wired. Checked continuity on all ignition wires, and all the fuses I could find. Don’t know what to check next — any ideas??
Crosbyman
you are going to have to track it down with a volt meter
recheck ( ohm TEST !!) all fuses on the PDP one 10 amp feeds the switch
Some PDP (if you search google ) have bee known to have bad solder joints on the B+ input to the PDP they can be resoldered if handy with a soldering iron .
how's power trimming doe it work ?
Blueglass49
PDP or relay
Thanks, I’ll check that next. Yes, the power trim works ok.
