Evinrude 200hp voltage????
eula30
Hi there, in a 1994 evinrude 200hp. Any idea what’s the Voltage from the power pack to the coil? (I got in DC 2.6V) and from the coil to the spark plugs? I got in DC 2.6V), I'm trying to find out if the coils are bad or the power pack. Motor was running fine until yesterday, didn't start, I check for voltage on Power pack and coil and I only got 1 coil out of 6 with 2.6V going to the spark plug the rest of the coils (5) I got 0 Voltage. How can 5 coils quit at the same time? I check the power pack and every wire that goes to the coils has the same voltage 2.6V so I'm guessing that the power pack is fine, I really appreciated any help <br />Thank you
eula30
Re: Evinrude 200hp voltage????
any idea what is the best repair book for this motor, there are different brand and I don't know witch one in better.<br />Thank you
Joe Reeves
Put the voltage check aside for the moment and check for spark.<br /><br />Remove the spark plugs. Rig up a spark tetser whereas you can set a 7/16" gap. Crank the engine over and observe. The spark should jump that gap with a strong blue lightning like flame.... a real SNAP!<br /><br />If not, disconnect the instrument wiring harness from the engine so that the ignition switch etc is not attached to the engine electrical system.<br /><br />Now, crank the engine by using a small jumper wire from the battery side of the starter solenoid to the small 3/8" nut that energized the solenoid/starter (not the 3/8" ground nut)<br /><br />If you now have the proper spark, in all probability the ignition switch is shorted, in which case, replace it.<br /><br />If still no spark, look closely at the stator under the flywheel. The large black coils that you see at the rear portion of the stator (usually at the rear area) provide approximately 300v AC voltage to the powerpack. Should they be cracked and/or melting down a sticky substance on the timer base and block, replace the stator.<br /><br />The stator is a two fold component. The small coils provide AC voltage to the rectifier which converts that AC to DC voltage in order to charge the battery. The large coils provide voltage as mentioned above to the powerpack.<br /><br />When the large coils melt down (never ending problem), the voltage to the powerpack drops which results in erratic and eventually no ignition. Let us know what you find.<br /><br />Spark Tester - Home Made<br />(J. Reeves)<br /> <br />A spark tester can be made with a piece of 1x4 or 1x6, drive a couple nails through it, then bend the pointed ends at a right angle. You can then adjust the gap by simply twisting the nail(s). Solder a spark plug wire to one which you can connect to the spark plug boots, and a ground wire of some kind to the other to connect to the powerhead somewhere.<br /><br />Using the above, one could easily build a spark tester whereas they could connect 2, 4, 6, or 8 cylinders all at one time. The ground nail being straight up, the others being bent, aimed at the ground nail. A typical 4 cylinder tester follows:<br /><br /><br />..........X1..........X2<br /><br />.................X..(grd)<br /><br />..........X3..........X4
eula30
Hi there, thanks for the quick reapply, the ignition switch was bad, and the ground wire on the ignition switch didn’t let the motor to start. I replace it with a new OMC Switch and wala the motor start and works the way it suppose to, Mr. Reeves I really appreciated you help.<br />Thank you
Joe Reeves
You're welcome I'm sure. Now, where do I send this bill? (grin)
