Can I please have some assistance with this problem? I've checked through the forums but am still not sure where to go.<br /><br />Engine is a 1972 Evinrude 25HP Model 26203R. Whilst out yesterday and running at a cruise for 15 minutes (certainly not WOT) the engine stopped dead. Suspect that power had decreased over the previous 5 minutes. There was a moderate headwind and we were heading against a very slow outgoing tide but nothing major in the way of resistance.<br /><br />I suspect overheating as the WD-40 I religiously spray the engine with after each trip was boiling off like crazy and the vapour leaking out the cowling. Tried to pull the rope over as soon as it stopped to ensure it hadnt seized and despite not starting it still turned over OK.<br /><br />Let things cool down and thankfully the engine started up fine and I continued on my way for another 20 minutes at a much reduced pace. Headed up river and swam for a couple of hours which was good as it was a stinking hot day at about 40 degrees Celsius (104 Fahrenheit).<br /><br />Against better judgement I headed back up to a cruise speed on the way home and things appeared to be OK although I think we may have lost a little power a few times and nudged the throttle up just a tiny bit to keep a constant speed. The wind was now at our back and the tide slack.<br /><br />Pulled the cowl off the next morning and noticed that a silver aluminium plug (has numbers on it) on the right hand side of the engine powerhead (looking from back) had become dislodged. This plug is a marker of some kind and just goes into a blank hole but I suspect it fell out due to the different expansion rate between it and the main casing.<br /><br />I replaced the water pump in this engine straight after I bought it before running it and it seemed to be OK up to now although I have never ran it at cruise (75 % throttle) for any longer than 10 minutes.<br /><br />When I bought it this engine it had never been run in salt water and all the internals including the metal water pump housing looked like new. I pulled the thermostat this morning and tested it in boiling water and it opened fine. Once again the housing and cover look like new. I also note a small rubber restrictor in a small hole to the rear of the large hole for the thermostat that covers a very small water passage?<br /><br />What could be causing this overheating problem? The fuel was fresh and mixed at exactly 50:1 with quality oil.<br /><br />This engine doesnt have a pee hole as such but blows a fair bit of spray and exhaust out of the relief hole high on the leg. <br /><br />I really want to resolve this issue and dont want to turn the motor into scrap by toasting it. Unfortunately this engine doesnt even have a buzzer let alone a temp guage.<br /><br />Some help on this matter would be greatly appreciated.<br /><br />Cheers<br /><br />Glenn
