Evinrude 25..
2mate
Hi guys i recently rebuilt a 1998 Evinrude 25hp (be25elece) as it had been submerged and sat in my friends garden for years. I have got it to turn over beautifuly but there is no spark. The coils have a bit of rust on them, would the salt have killed them?
dew2
Re: Evinrude 25..
They may not have a good ground,remove clean and try again.
2mate
Re: Evinrude 25..
Hi there,
I sprayed the cylinder head whilst rebuilding it, could the paint be stopping it?
Also could the powepack be faulty?
dew2
Re: Evinrude 25..
Possibly,It dont hurt to check all the connections.it cost nothing also
Sixmark
Re: Evinrude 25..
The mounting pad that the ground wire from the coil goes to should be free of any paint and corrosion to make a proper ground for the coil.
boobie
Re: Evinrude 25..
I'll go along with checking ALL the ground wire connections for being good, clean and tight.
2mate
Re: Evinrude 25..
Hi guys well i cleaned everything today and checked but still no spark, took the power pack off and it has cracked on the bottom(see picture) could this be the problem?
2mate
Re: Evinrude 25..
Just to add the powerpack is not the coil but the pack on the side of the engine held in by two bolts.
