Working on brotherinlaws 25 HP. It keeps fouling plug on lower cylinder, causing cyl. not to run. After 1/2 hours of run it starts cutting out on cylinder. We have checked fuel pump. Plug is black wet and very soothy. Compression is fine-120 on both. Both sparks will jump 3/8 gap, only difference seen is that lover spark looked white- like ( hard to see in sunny day ) It got new pionts and condencers last summer. we tried to swap coils, but problem stays at lover cyl. When new plugs in, it runs fine for the first 1/2 hour to favorite spot. When it then gets restarted, It starts not running on lower ???? I tried to unscrew fuel pump and squese bulb, but pump didnt leak through vacuum hole.
