Evinrude 25hp help
2mate
Hi guys just wondering if you can help my transom clamp on my evinrude 1974 25hp has snapped off and the actually threaded bit is siezed. Any ideas on how to remove?
Cheers
F_R
Re: Evinrude 25hp help
Drill two small holes, side by side, lengthwise, through the screw. Then, keep drilling the holes with progressivly larger bits till they reach the threads, and hopefully intersect in the middle. Then the screw will hopefully collapse toward the center and you can remove the pieces. Can be done, takes practice.
1946Zephyr
They sell replacement kits for those once you get the old one out.
dew2
I'd use a sawzall cut it near the transom,Then use a pipe wrench after its off the boat.If you have no sawzall a hacksaw.
samo_ott
Personally I would not use an easy out, I have never had luck with em. I'd drill it out. Some folks use left handed drill bits to do it. If I had some I'd try it also but normal ones work well also.
boobie
Stay away from the Easy Outs. If you break one of them off you've got some real probs. Stick with the drilling it out as FR suggested.
