Evinrude 28HP Time Setting
3putt
I would like to know what is the correct timing setting.<br />Model # VJ28ESLCCR<br />Serial # 7817798<br />Also what is the correct year model.
steelespike
Re: Evinrude 28HP Time Setting
My chart indicates 88.<br />If you get yourself a manual it should be easy to<br />check timing.<br />There are numerous aftermarket manuals.<br /> You could check at the library.
3putt
I am checking the work of a mechanic who did not have a manuel. <br />I now realize that I need a manuel in order to check his work. And if I had a manuel then I would not have had to ask this question. Thanks<br />for your advise.
