Re: Evinrude 30 HP question
Welcome to the forum.<br /><br />How long is a little while ?<br /><br />If you dont have a service manual for the motor, first get one, it will be the best $ you spend on it. They are available thru this site, click on the manual link in the upper left corner of this site.<br /><br />If you do not know when waterpump impeller was changed, and it wasnt within the last year, I would suggest you to start there. I would highly recommend you to remove, disassemble carb, soak overnight in carb cleaner, and install a fresh rebuild kit. Change lower unit oil, and install a fresh set of plugs. Follow steps in manual, for doing a carb/ignition sync'linck syncronisation, and you are good to go.<br /><br />If you are mechanically inclined, DIY service is easy.
