Re: evinrude 33hp year??.breaker points..when should open,close
Sebbbe..... Double check that model number, something's not right there.<br /><br />Turn the crankshaft until the flywheel key lines up with the rubbing fiber of the points. Set the points at that position so that a .020 slides through but that a .022 will not. Then do the same with the other set of points... flywheel key, fiber etc. That's it.
