jdlloyd_iboat
- Joined
- Jan 15, 2006
- 52
I have a 1989 Evinrude V-6 150HP that I have run for about 20 hours since last July when I bought it. From yhe start the regulator was not working and therefore not charging the battery. I was reading in these forums that not having a regulator that is operating might be detrimental to the stator (causing it to overheat). I also read that replacing the regulator w/o replacing the stator will likely result in a failed regulator. My motor seems to run well. I don't really need the battery to be recharged the way I operate. Since it seems that I would need to replace the stator if I replace the regulator, should I just wait for the stator to fail? These parts are expensive -- several hundreds of dollars and it seems like preventive replacement would only avoid a possible need to be towed. What is the advice?
