I have the same problem as Redeemed does in another post. A 35hp 1980 Evinrude which pops out of gear underway. I have determined through this forum and a mechanics verdict, that the clutch dog and possible the forward gear needs to be replaced. I have no metal chips in the oil. I decided to do the work myself. I am using the Clymer Shop Manual. The shift rod connector has been unbolted through the water intake ports. The 5 bolts have been removed, BUT the lower unit will not seperate. The back will seperate about 1/8 of an inch but the front will not budge. Am I missing anything? How much pressure needs to be applied to seperate the unit? The last thing I want to do is cause more damage. Any help here would be appreciated.
Thanks
Paul
Thanks
Paul
