Evinrude 35 or 40
unleaded
i bought an old starcraft years ago with a '76 evinrude 35 long shaft on it that i just recently brought home from storage. i can't get it running although i haven't really taken anything apart yet - don't know if i wanted to go down that route.
i just recently traded off some stuff and received a '74 evinrude 40 short shaft that runs decently in return. if i wanted to use this one i'd have to change it to a long shaft. the 40 is huge compared to the 35 and has the old school mount that won't accept through-tube steering cable. can the mount from the 35 be used?
can i/should i
a) throw the 40 onto the 35 shaft/mount
b)extend the 40 shaft
c)get the 35 running and sell the 40 or use it for parts
d)other suggestions
thanks! this forum is pretty great and i've learned alot just by searching what i need!
unleaded
Re: Evinrude 35 or 40
and anyone with experience with both, which is the better motor?
jimmbo
Two totally different designs. The 40 has a lot more torque, the 35 has a more efficient gearcase and propeller design. You cannot swap parts to create a 37.5. My dad owned both, they each had their charms, but I like thru hub exhaust, so the 35
unleaded
great thanks, i think i'll shop for a long shaft kit for the 40 and just get the 35 running
1946Zephyr
Yep, the 76 and newer 35 was a completely different design the to earlier 40. The 74 40 was based on the old 33hp SkiTwin which was also based on the '57 35. Your model 35 is a completely newer style design and the 25 follwed the newer design in the following year.
unleaded
from the looks of your sig i think you have a bit of experience with rudes. lol
1946Zephyr
Yep, unfortunately, my collection won't fit in my sig :D:D I'm a big fan of the oldies.
If I was you. I would find out what is keeping your 35 from running. These motors aren't that tough to work on. I'm betting that you will need a carb rebuild and possibly a new fuel pump. The ignition system is electronic and likely is fine.
unleaded
yeah that's what i'll do although i already bought an extension on ebay to make the 40 into a long shaft too. lol
1946Zephyr
Well, those 40's are great motors. I actually like the model that you have. It still has the old style ignition and it has the older style midsection and lower unit. Excellent old motors and very reliable. It's actually a better motor than the 35 and cheaper to fix, if something goes wrong. Coils and ignition parts are cheap and all the other maintenance items are too.
It wouldn't be a bad idea to keep your 35 as a spare and liesurely get it running good.
unleaded
going to throw the 40 on it tomorrow to see how it lines up. tested the 35 today, no spark so it will be a project for the winter in the basement if i can sneak it past the wife.
1946Zephyr
Well, if you want to sneak a motor past the wife, wait till she goes off with the girls.
:cool:
unleaded
yep good idea - she won't hear me stumbling down the stairs with it then :)
