Evinrude 35hp Big Twin
MALC
have purchased an evinrude 35hp big twin but there does not apperar to be any serial / model no. plates. is there a specific location for these details. if not then what year is the engine please............... casings are blue and white if that's of any help. thanks malc.
Willyclay
Re: Evinrude 35hp Big Twin
Welcome to the iboats.com forum. The experts here, which I am not, can help you fix any problem with a boat, motor and trailer. There are two standard locations on Evinrude (OMC) outboard motors of that era that display model and serial numbers. One is on the side of the transom bracket and it should be a metal plate with the info engraved. The other is a quarter-sized aluminum disk pressed into the top, rear of the powerhead . Good luck!
jbjennings
It's newer than a '56 (30hp then). If it's blue/black/white on an aluminum cowl and has a 2-line hose it's either a '57 or '58. IF the cowl is fiberglass it's newer.
as said, check the plug in the side of the motor.
JBJ
