Howdy All.<br />I have a '86 Evinrude 40 horse VRO motor. During a two week fishing trip (never when you are at home) a problem started. I can start the motor and it idles fine. I accelerate fine. But, after running 15-30 seconds the engine cuts back to idle speed, then revs, then idle. If I take it back to idle on the throttle it smooths out, then if I accelerate it happens again. IF I pump the fuel bulb off of the tank while running I can cure this problem. When I opened the engine cover I tried to trace the fuel lines. I replaced the fuel filter. Then I noticed that after the VRO pump the fuel lines splits into 3. One I can see goes to the top carb. The middle one was pinched off considerably between the pump and starter, which I rectified. I have not run it since.<br /><br />Questions:<br />--Does it sound like a fuel restriction problem?<br />--Could the pinch be causing the problem?<br />--Where do the three fuel lines go?? One to each of the two carbs....<br /><br />Kicker...I ran like this for two weeks. The last day the VRO warning started going off. A beep every other second, which I think means engine not getting oil.<br /><br />Thanks for any help...
