Re: Evinrude 4hp earth?
The two hp does have a "ground" wire. ("Earth" to you). It needs it because the magneto armature plate is isolated from the crankcase by a plastic bushing. The spark from the coil goes to the spark plug, to ground, and back to the armature plate to complete the circuit. If the armature plate is isolated, the circuit is broken, thus the ground wire.
Most motors do not have a plastic bushing on the armature plate, thus no need for a ground wire. (Sorry, "Earth" wire.)
