Re: evinrude 6 horse fishernan 71
It may have something to do with being in a barrel. How deep did you have it? The pump needs to be submerged.
On the other hand, the impeller may have chosen that moment to disintegrate. Consider yourself luck you weren't out on the lake.
1. Remove the spark plugs
2. Put motor in forward gear
3. Remove the four bolts holding the lower unit on
4. While putting downward pressure on the lower unit, slowly rotate the flywheel. There is a pin that must align with a slot. When it aligns, the lower unit will come down a bit more. STOP turning the flywheel and don't turn it again till it is back together.
5. Now look in the gap and you will see the brass shift rod connector. Remove the accessable screw.
6. Now the lower unit will come down and away. Note the position of that pin for reassembly. The pump will be right in front of you. It is NOT necessary to remove the pin. Unbolt the pump housing and pull the shaft out of the unit.
7. For reassembly, put the shaft/pin in the same position. When reinstalling the shift rod screw, use a flashlight and make sure the notch is precisely aligned with the screw hole before installing the screw. Failure to do this will cause the screw to drag on the edge of the notch and it will wipe the threads off the screw every time. Then it will fall out five miles from shore. Never at dockside.
Impellers are available right here at iboats. Look it up for the price.
