Hi all,
I have opened my engine because the cilinder compresion was 120- 40- 120. The second cilnder was down the second.
When I open it the head gasket is burned.
Please see attached pictures.
Somebody mentioned to me that the piston can be melted and that means open the engine and redo it.
Based on the pictures, can you tell me:
1) Are the piston melted? Do I have to replace them or I can test the compression that I have with the new gasket and continue running.
2) how I can test the overheat beep? because I do not remember that I had any alarm about it.
3) Base on what you can see, may I replace the thermostat. water pump, gasket and continue using it.
