I recently bought a boat with a 1972 Evinrude 65hp 3-cylinder. Aftter kitting the carbs I put muffs on and started it up. I checked to see that there was adequate water and found water squirting out of the lower unit in several different directions from small holes (not the flush hole) all about 1/8" diameter. The water was not from any gasket area or mating surface. Is this normal for this engine?<br />Larry
