Hi, I have 1969 6hp Evinrude. It starts and runs (however very poorly - spitters and chokes) when I put the selector on handle in the "Start" position, but if I move the sevector even 1/8 of an inch further (increase) it dies right away. If I decrease, it also dies. Here is what I have checked:
1) Compression is 100/100
2) Fuel pump seems to be fine- even tried with constant pumping with priming bulb.
3) Cleaned spark plugs (new last year, not even 20 hours on them)
4) Tried to synchronize the linkage as per manual - adjust the notch on carb follower with little arm on carburator - did not seem to make any difference.
5) As per manual this motor does not require setting of ignition timing, so not sure.
6) Carburator was rebuild last year - all new seals and gaskets
Gas is fresh with 25:1 mixture.
I am not even sure what to touch next.
Please help, any suggestions are welcome.
Thanks again!
Oleg
Thanks again!
Oleg
