Evinrude 7.5hp model 7518
Xzanth
Ok so I got this motor. It seemed ok but air was coming out of the spark plug hold so I took her out. Well the threads came out too. And it looked repaired before. So instead of a 400$ time serts purchase I got a new head with a head gasket. I've cleared the Pistons and Chambers, changed all the gas lines. I've converted this from the pressure tank to a single line using exact methods. The gaskets to the carb looked good so I cleaned the carb and all that. Now I'm not too savy with motors and stuff. So I'm not sure what a float bowl needle or that is. But I assembled everything by following on here. There are just a few things I don't know. How to check if the motor is getting spark, compression, those sort of things. . Now I got it all together. Mixed gas 24:1 pumped it. And it fired up.. I reved it up. It sputtered a lil (hasn't been fired up for a while, but after a little working in. It sounded nice.. but after about 30 sec it cut out.and it wouldn't fire up again. I gave it a half hour and squeezed the bulb again.. it fired up again. Did the same thing.. any help would be good. Things with the motor seem fine. But maybe too much gas? No gas? Also these knobs on my motor. What do those do.? I've searched but couldn't find any info fast
Joe Reeves
Carburetor adjustable needle valves... Top needle valve is the slow speed adjustment... Bottom one is the high speed adjustment. Top one is more-so a sharp needle pointed valve... Bottom one is more of a shorter blunt needle.
(Carburetor Adjustments - Two Adjustable N/Vs)
(J. Reeves)
Initial settings are: Bottom high speed = seat gently, then open 1 turn out. Top slow speed = seat gently, then open 1-1/2 turns.
Setting the high and low needle valves properly:
NOTE: For engines that DO NOT have a shift selection, obviously there is no NEUTRAL position. Simply lower the rpms to the lowest setting to obtain the low speed needle valve adjustment.
(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, waiting for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting.
(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
When you have finished the above adjustments, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
A compression gauge can be found at any auto parts store... reasonably priced (actually cheap!). Some are designed to screw into the spark plug hole... others have a rubber tip and are hand held. The hand held obviously requires two people unless the engine is a electric start model.
The spark is checked with the spark plugs removed. A adjustable sir gap spark tester is required (auto parts store or build the following) whereas you can set a 1/4" gap for that magneto model... the later electronic solid state ignition models use a 7/16" gap. The spark should be a strong blue lightning like flame, a real SNAP!
(Spark Tester - Home Made)
(J. Reeves)
You can use a medium size philips screwdriver (#2 I believe) inserted into the spark plug boot spring connector, then hold the screwdriver shank approximately 7/16" away from the block to check the spark or build the following:
A spark tester can be made with a piece of 1x4 or 1x6, drive a few finishing nails through it, then bend the pointed ends at a right angle. You can then adjust the gap by simply twisting the nail(s). Solder a spark plug wire to one which you can connect to the spark plug boots, and a ground wire of some kind to the other to connect to the powerhead somewhere. Use small alligator clips on the other end of the wires to connect to ground and to the spark plug connector that exists inside of the rubber plug boot.
Using the above, one could easily build a spark tester whereas they could connect 2, 4, 6, or 8 cylinders all at one time. The ground nail being straight up, the others being bent, aimed at the ground nail. A typical 4 cylinder tester follows:
..........X1..........X2
.................X..(grd)
..........X3..........X4
