Evinrude 70 tlend
elbeau54
Can’t get my 1992 70 tlend to turn over. New switch and solenoid,no change. I checked fuses and they are ok,I can jump the starter but not start from ignition switch. Changing the sol and switch did nothing.
oldboat1
Try moving the shift lever backwards and forwards a bit in the neutral detent, with the key switch held in the start position.
Try using a jumpr wire from battery post on solenoid to the small post on solenoid.
