Evinrude 7520 clearance question
TINCAN46
I recently purchased a 7520 powerhed. I noticed it has a slight amount of movement when lifting the flywheel vertically. Is there a thrust washer on the crankshaft or case that may be worn? Or is this something that I shouldn't worry about? I haven't installed the.powerhead yet so now would be the time to replace anything worn. Are the gaskets available for a tear down? Thanks Jim
There is no thrust washer.----Remove bypass covers and inspect pistons rings.---Check connecting rod for clearance.----Remove cylinder head to inspect cylinders.
F_R
Crankshaft end play is normal. And there is no adjustment or shims. Now of course if it is totally worn out, that is a different matter.
