Folks,<br /><br />I bought an 5.1meter bought with an 1982 Evinrude, 70 HP, 3 Cylinder 2 stroke engine. When I took it out for a run with the previous owner it went well with no probs. I took it out yesterday for the first time since I bought it and 5 minutes into the journey, the engine stalled. It started again immediately, however when I put it in forward or reverse it stalls again. It started okay again and stalled the moment I put it in gear. Didn't know why this happened. I fueled it before taking it out with a 100:1 gas to oil ratio. Owner told me he had been using 100:1, while literature says it sho
uld be 50:1... So what should it use for the future?<br /><br />Now when I got home, I put the water muffs on, and<br />started it, put it in gear with no problems. Everything was fine... however 5 minutes later, while in gear and at about 4000 RPM, the motor shut, and it won't start. <br /><br />It seems that the starter can't turn the flywheel. The starter gear hits the flywheel and gets stuck there. It seems that the flywheel is stuck! Not sure if this is a broken cylinder, gear shaft, broken piston rings... Has anyone seen this before? What do you think it might be?<br />What should I look at? any tips on how to troubleshoot would be great.<br /><br />thanks,<br />Dan.
