Evinrude 85 V-4 two stroke seized
cmendrek23
so i just got a free 16.5 ft bayliner on a trailer with an 85hp evinrude. no idea on the year of the boat or motor. and let me state that this is my first boat, and im an auto mechanic (and race motocross) but never worked on an outboard before. anyway, after 3 - 55gal drum fulls of pine needles, mud, leaves and sticks, and a thorough shop-vac session...power washer and all kinds of chemicals, the boat is in MINT condition. Then engine however, not.
took the heads off because the starter kicked up and would not crank. after vacuuming out the rats nests, the cylinders are covered in rust. rings are seized to the walls. so i stripped the entire motor of its electronics and stator, clutch etc. took off what looks to be the reeds and now i can see down into the crank shaft area as well as the sides of 3/4 pistons. pulled the carbs and those are in great shape (thanks to the reeds the rats couldnt make nests in there. to make a long story short, i took off everything off the block itself and soaked the block in mystery oil for a few days now...each day spraying more and more on it from a spray bottle. the lower 1/2 (below the rings) of the pistons look good...and everything inside the crank looks good and rust free....but it still wont even budge.
my question is...how do you take the actual block off the outboard itself? ive removed the covers and revealed what seems to be 10 bolts going through and into the block...but it still wont budge. i understand theres a shaft that runs down to the prop...how do you get that out? i just want to remove the block (or is it powerhead?) and soak it in a drum of old engine oil and see if i can get it to spin. then ill go ahead and disassemble the block and hone out the cyl and new rings on the pistons to give it life again. carb clean with a sync and should be good to go.
i assume the engine sat for about 3-4 years (along with the boat) under a big ol pine tree....i found it with no tarp or engine cover on...prop is missing so the rats climbed up the exhaust and made nests that way in the 2 lower cylinders in front of the pistons. the engine itself doesnt look to have seized due to overheating or failure...just from rust and not being used...
any help is SO GREATLY appreciated!
THANKS!
EDIT
Thanks again!
wilde1j
Re: Evinrude 85 V-4 two stroke seized
Get an OEM shop manual if you don't want to break stuff.
tal
To answer your question - you have to remove the foot or lower unit. Underneath the carbs there is a shift rod that comes up and connects to the linkage. Disconnect the rod from the linkage if you haven't already.
Then take off the 2 bolts on each side of the foot. There's also a bolt in front of the trim tab and one UNDER the trim tab. If you're lucky the foot should then drop off, but the shaft may be rusted in up there at the block.
I'm not sure about the # of bolts (10) you took off, might want to double check to make sure you got all of them.
wilde1j
The powerhead must be removed from the midsection before any significant dis-assembly can be done. Don't try to split it until it's off. Put those 10 or so bolts back until it's off. Not kidding about the shop manual, but hey, it's your motor.
cmendrek23
ok ill double check that and make sure...
any chemicals besides mystery oil and used motor oil that would help in dissolving some of the rust? coca-cola maybe?
tx1961whaler
50-50 mix of ATF and acetone
boobie
Dang you Whaler you beat me to it. You must have read that thread also. I've tried it and it does work but you have to add one more thing into it. Let it work and do it's job.
