cobra grover
- Joined
- May 16, 2012
- 9
The son and I bought a used jon with a 8hp Evinrude. The number on the side of the motor is E8RCEC. We can get it started pretty easily but can't get it to idle. If we pull out on the choke knob slightly when it starts to die it picks back up. Push in the choke and repeat the process. We took the carb off and got a rebuild kit. Turns out the rebuild kit was the wrong one so we just sprayed all the pieces and parts with carb cleaner and put it back together. Runs a little better but still the same issue. From my searches it seems it must be a dirty jet or an air leak somewhere.
Any ideas?
From the scematics I found I can only find a slow speed jet on my carb.
Any ideas?
