driver0606
- Joined
- Sep 9, 2015
- 56
I have a 1989 Evinrude 9.9 with 15hp carburetter on a 9 ft. speedboat used in salt water. In the last 4 years it has always been flushed out with fresh water at the end of the season. It started running too hot last year. The impellor looked OK but was changed and the thermostat removed, without improvement. I then took the lower unit off again and connected a garden hose to the tube that runs up to the powerhead, with the thermostat cover off. For a while there was no result then suddenly water began to flood out. Once reassembled the engine ran normally at all speeds.
This year the small stream of indicator water runs just warm at low speeds, but gets very hot/boiling if the engine is run at max power. I prefer not to strip the engine. Any ideas, please?
