Evinrude 9.9/15 remote cable setup
denL
In the following thread Lion Hunter posted pictures of his 9.9 remote setup.
http://forums.iboats.com/showthread.php?t=351618&page=1
I have a '86 15hp with the remote kit 0398032 and an older Simplex controller that takes the Long Life cables. I'm starting to wonder if I need to buy a different controller. Can I use those cables with that same kit to connect the shifter? I have the throttle figured out but I can't figure out how to connect the shift cable. I looked at the pics but the don't show the cable ends. Thanks.
dew2
Re: Evinrude 9.9/15 remote cable setup
The first two pics are the shift connection in your refered to thread,The thumb screw you see in the first pic has a key on the opposite side.It fits into the slot on the shifter on the motor.Its round with a ear each side and fits in the shifter, its spring loaded turn it vertical push it into the slot and turn it horizontal it is then locked in.
I may not explain very well and have no pics I do have all the hardware off a 1980 7.5 johnson not the cables tho.So no pic. Some pics from you with the mount and cables might help.
denL
Thanks. I can post pics tonight. The problem I'm having is connecting the cable end to the sleeve because the cable end is only a bare wire. I probably need another part that connects to the wire and slides into the sleeve, but I'm not sure what to order, yet.
