Mi_fiveo
- Joined
- Jul 22, 2018
- 115
I have a 1999 Evinrude 9.9 4 stroke that I’m trying to install for my kicker motor. The guy I bought it from said it wouldn’t stay running and needs a new carb kit. After getting it all hooked up and adjusted as close as I can follow the manual, I’m having a hard time getting it to run. If I push the choke in and turn the key it will not fire at all. If I turn the key a million times without pushing the choke in, it will occasionally fire up for just a second. If it does start to run, I can lift the choke lever and it seems to run decent but it will always quit running after 20-30 seconds. I had it running at one point but when I tried to lower the choke lever it died out. I pumped the primer bulb as it was dying and it made no difference. The bulb was hard and full of gas.
With all the times I have tried to start it, gas is dripping from the tube in the back. I tried to check for spark by grounding a plug and watching. It did not spark most of the time but a did see a few quick flashes intermittently. Any ideas to help me problem solve this motor? I’m leaning torwards a loss of spark more than an engine starving for fuel, but i could be way off base.
