DeanHensler
- Joined
- Feb 14, 2013
- 82
I just picked up a 1992 evinrude 9.9. It had been sitting for a while before I bought it. The guy I bought it from ran it in a tank for me so that I could see it run. The thing ran perfect in neutral, forward and reverse.
I brought it home and put it on a stand. After sitting for a few hours I see its leaking a BLACK oily substance. The leak is at the front of the prop where the prop meets the lower unit housing.
I read on Leroy's Ramblings that these engines push the exhaust through the prop and can leak about black oily substance out the prop if they've been sitting a while (mixture of exhaust and carbon build up causing it to be black). This would all make perfect sense, but it isn't leaking out the center of the prop but rather the front of the prop where it meets the lower unit housing.
Is this normal or something to be concerned about?
I've attached a picture to point out where the oil is leaking from. This is not an actual picture of my motor.
