evinrude backfire after new powerpack and rebuilt carb and still will not run
buckeye700179
1968 100hp evinrude won't run. just bought a new powerpack and i'm getting spark and gas the motor will start and then die's and backfires.<br /><br />thanks Roger
johnbates
Re: evinrude backfire after new powerpack and rebuilt carb and still will not ru
I dont know to much about boat motors .but alot about auto engins...Are you sure that your plug wires are correct...maybe timing
buckeye700179
i double checked the wires and they are correct. it kind of sounds like you and i are in the same position.we know alot about automobiles and very little about over grow weed eaters. but thanks for the help
johnbates
another thing...does your pwr pack have point and a rotor button? My 1964 johnson 60hp it did the same thing and I had the rotor button on 180 degres..I dont know just trying to figur it out
buckeye700179
i preety sure that the rotor will only go on one way but i will double check it to make sure that it is on correct.<br /><br />Roger
buckeye700179
ok i checked the rotor and it was in the proper place. this boat ran fine before the powerpack went out.insalled the new powerpcack starts and stalls with a backfire. it's got me stumped!
buckeye700179
also tested the paulse transformer it came back fine. we also tested the sensor under the flywheel and it showed 5.6 ohm's witch my book says that it should read between 4 to 6 ohm's but it still trys to start then it backfires does anyone have info to help me out <br /><br />thanks roger
OBJ
Hey buckeye....just fer' grins....check the point gap settings. Should be .010. Check the flywheel key has not sheared a little throughing timing off. And, make sure the flywheel is torqued to specs. I think the torque is 100 to 105 foot pounds.
D
DJ
Guest
Do you have the spark plug wires on the right plugs? Why do I ask? Been there, done that, same symptoms. :eek: <br /><br />Agree with OBJ. Check for flywheel key sheared also.
buckeye700179
the plug wires are correct and the flywheel and key are in the correct place i just redid the flywheel because i thuoght the same thing but all that was fine. i am really begining to lean to this new powerpack being bad. like i said the boat ran fine untill the pack went bad and nothing was changed but the pack it's self. but ibought this pack from joe reeves and i don't think it would be bad because he really seems to know what he is doing with theese old v4 engines.
buckeye700179
ok, guys i just got an e-mail from joe he said that it sounded like a card problem so what i need is a rebuild kit and# for it does anybody know where i can get one for it. 1968 evinrude 100hp is has the 4 barral carb
buckeye700179
just had the carb rebuilt it cost me another $250.00 and still backfires and dies does anyone have ideal what i should do next.<br /><br />thanks Roger
buckeye700179
also thenew power pack has two black wires that come out from the pack. correct me if i am wrong but both of these wires are to be grounded?
buckeye700179
hmmmmm
Joe Reeves
That new powerpack came with complete instructions. Do not connect any wire without being absolutely sure of where they connect via the instructions.
buckeye700179
cost to much to do something that supid
Joe Reeves
Sorry, my last post wasn't intended to be a insult to your intelligence.<br /><br />A thought just occured to me about power (12v) being supplied to the powerpack at the proper times.<br /><br />The ignition switch actually has two "ON" positions...... the START position and the RUNNING (normal on) position. It is possible that 12v is only being supplied in the START position.<br /><br />With the ignition switch in the RUNNING (normal on) position, using a voltmeter, check to see that 12v is indeed being supplied to the powerpack in that normal running position. If there is no voltage to the pack with the key in that ON position, the pack will only fire when the starter is being engaged via the START position.<br /><br />One other thought..... The bakelite rotor has a notch, actually not a notch but more so a protruding key that keeps it aligned with the crankshaft. I've had a couple occasions whereas that notch/key had been broken off which in turn allows the rotor to move, throwing the timing off.<br /><br />The distance between the metal rotor and the ignition sensor should be set to a tight .028 . I'm playing on memory about the .028 setting as I don't have the manual in front of me but I believe that setting to be true.<br /><br />EDIT 04/05/04 - 09:18pm<br /><br />One other thing I thought of in the form of a test..... pulling from memory here.<br /><br />With the flywheel off and the distributor cap set aside and bakelite rotor removed, remove the high tension wire from the coil (power transformer), then unscrew the wire from the distributor cap.<br /><br />Now, insert the wire back into the coil (power transformer). With the key in the ON position, check to see that 12v is being applied to the powerpack. Hold the other brass screw end of the high tension wire 1/4" away from a ground... some area of the block. slide a feeler gauge back and forth across the sensor face that's attached to the timer base.<br /><br />Does that action make a hefty spark jump from the coil wire to the block/ground ?
Joe Reeves
^ Bumped for above edit.
CARDNAL98
Re: evinrude backfire after new powerpack and rebuilt carb and still will not run
I Had Same Prob With My 135 Outboard What I Found Wrong With My Outboard Is That I Was Getting Air In The Carburetors. Make Sure That All Fuel Line Are Tight And You Can Put Sone Gasket Glue On Basket Between Carburetors And Intake Manifold Try These Thing On Your Outboard It Mite Fix Your Prob It Fixed Mine Hope This Will Help
