Re: Evinrude Big Twin 35 cutout switch
Hello Paul,<br /><br />Your diagnosis was right on target. After a bit of searching, I found the Mercury switch on the speed adjustment shaft. Well, it turns out that this switch has no wires leading to it, so as you thought, it was this open condition that was the problem. I will replace the wires to this switch, and and see what happens. According to the wiring diagram, it looks like one lead goes to the base of the cutout switch, and the other goes to the ground on the engine frame. <br /><br />If I understand this circuit properly, at a low throttle position, the starter circuit is completed through the Mercury switch. Once the engine is running, as the throttle position is increased, the Mercury switch opens so the starter circuit is no longer complete. If the rpm of the engine goes too high, the vacuum becomes strong enough to close the contacts, grounding the ignition coil. <br /><br />With that in mind, if the coil was grounded when I jumper out the cutout switch, why did I still see a spark as I cranked the engine? I was checking compression and spark strength with the a jumper across the cutout switch to allow the engine to crank for these tests. I did not have the fuel supply connected at this point, so the engine never actually ran. But, I did get a good spark...hmmm.<br /><br />Please accept one grateful "Attaboy" for pointing me in the right direction. I really do appreciate it. I wish we could send you a bit of the warm weather from here as a thank you. It was 16 degrees Celcius today, and sunny. My wife and I were married in Saint John, New Brunswick about 23 years ago, and we remember how cold it can be in that part of the world at this time of the year. <br /><br />Thanks again for your help, you seem to know your way around these motors pretty well!<br /><br />Howard
