Monkaroo
- Joined
- Aug 20, 2007
- 104
Hey guys , I have bought an Evinrude 175 ( 1981 model ) with the choke primer system . After having some problems with the engine bogging and stalling when I try to take off , I have discovered that it has two different types of carbs on it . The choke primer system has a fuel line which runs from the primer sylenoid to a nipple on top of each carb . One of the carbs looks to be new and has been installed on the two middle cylinders . The new carb doesn't have the nipple for the primer line to connect to , and has 5/16 on the face of it just below the barrels . The other two carbs have 3/8 on them . I'm thinking this is the size of the jets . After comparing the routing of the fuel lines from the primer sylenoid to the engine I also found that someone had plugged the nipples on the top of the top and bottom carb and had ran the primer lines to the bypass covers on the cylinders . I corrected this and ran the lines to the top and bottom carbs like my SELOC manual shows to be correct . I haven't taken it out again yet but have cranked her on the hose pipe and she seems to be ok on starting . My question is will I have to change the middle carb to the 3/8 with the fuel nipple like the others to get full performance . Thanks , Monkaroo
