Evinrude commercial outboard help ???
YOUWILLLOSE
Evinrude Commercial 25hp outboard, model no. SE25RPN, Serial no. G03655292. Could you please tell me the age please and any details about these motors ir performance/reliabilty
thanks
tashasdaddy
Re: Evinrude commercial outboard help ???
i tried but i can't identify, maybe someone else can.
HighTrim
Pretty sure that is a South American Evinrude made in 94. The standard commercial will have a different gear ratio. You will need to prop differently with these engines. The larger gear ratio case takes more oil, compared to the standard models. It takes different plugs, and there is no recommended constant high rpm plug. The engine is made to run on lower octane fuel as well I believe, although when do you ever see 85 octane gas for sale. Hopefully others will be able to highlight the differences better for you.
YOUWILLLOSE
HI,
Thanks for your information. Im supprised to hear of its origin as im in the uk but trust you guys are correct.
Thanks very much for your help and advice.
tashasdaddy
yes, you usually get the motors from the Belgium plant.
jay_merrill
Here's what I found:
S= South American Production
E= Evinrude
25=hp
RP=Commercial with programmed tilt
N=Counter Rotation or year built 2.
Counter rotation on a 25hp doesn't make sense but neither does jiust one letter for year designation because 1972 would be UN, 1982 would be CN, 1992 would be EN and 2002 would be ON.
http://www.brokeboats.com/omcid.html
HighTrim
This is the page that you need, it being a commercial outboard, the model number codes can be a bit different. The INTRODUCES coding system does not apply.
"http://www.skoterskroten.com/img/arsmodellstabell.pdf"
YOUWILLLOSE
WOW
Now im confused.
I dont think its counter rotation and have no idea what Programmed tilt means, can anyone explain please
You guys seem to be confirming it to be 1994 from south american build,
The N can also mean year 2 I think is what your saying - does that mean it may be 1992.
from what I read into it
Would I be right in saying its a 1994 commercial outboard with a larger gear ratio ( rh turn). Standard manual tilt ??. Built in south america.
Thats what I need to know bascially but would very much welcome any non-technical comments on its specifications please.
Thanks again for your kind help, no idea how you guys do it amazing.
HighTrim
It is a 94, dont worry about the N, that is coding for non commercial (recreational) outboards, where you use the word INTRODUCES corresponding to 1234567890, for outboards 1980 and newer.
