Evinrude cowl seals
Chrisham
I need one for a 1976 evinrude 40 hp.These are no longer available.I have several vintage motors that need these.Are there any aftermarket seals that will work
boobie
Try the marine salvage yards at the beginning of this forum.
anthill
I had the same issue on my 73 25hp evinrude. To compound the problem the lower motor cover is distorted one side is 1/4 to 3/8 wider than the other side. To fix it I greased the cowl, for a bond breaker, and caulked the gap with a polyurathane caulk.
It's ok, far better than nothing.
It is a weekend is it not -------You re not dealing with AMAZON here.-----Patience
Geezer1
I have used edge trim for boats from Taco Marine. It seals great and looks sharp.
